Inventor Forum
On-line help.... Gotta love it
3 REPLIES 3
karthur1
879 Views, 3 Replies
BTW, I do have the off line help installed. But, as long as the internet is still up, it will not use it unless I totally disable my network connection.  That is a pain to have to stop and do. Would be nice if there was a option to always use local installed help.
3 REPLIES 3
mpatchus
in reply to: karthur1
After installing local help files, If you always want to access the local help from within Inventor, you can modify the helpids.xml file located at:
C:\Program Files\Autodesk\Inventor 2015\Bin:
Change the default value  - UseOnline="1" - to - UseOnline="0"
The value '1'  - This will always launch the online help by default
The value '0' - This will always launch the local help by default
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
-niels-
in reply to: mpatchus
Hah, i was looking for the same topic but couldn't find it...
I remember there being the typo of "Inventor 2015", which you copied 🙂
Edit:
Found it, it was the post about the wikihelp retiring.
http://forums.autodesk.com/t5/Autodesk-Inventor/Wiki-help-retiring-Making-way-for-fresh-new-look/m-p...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mrattray
Just because... here's a link to an article on the benefits of offline help: http://beinginventive.typepad.com/being-inventive/2012/04/when-context-help-does-not-show-you-the-ri...
Mike (not Matt) Rattray
