BTW, I do have the off line help installed. But, as long as the internet is still up, it will not use it unless I totally disable my network connection. That is a pain to have to stop and do. Would be nice if there was a option to always use local installed help.
Solved by mpatchus. Go to Solution.
After installing local help files, If you always want to access the local help from within Inventor, you can modify the helpids.xml file located at:
C:\Program Files\Autodesk\Inventor 2015\Bin:
Change the default value - UseOnline="1" - to - UseOnline="0"
The value '1' - This will always launch the online help by default
The value '0' - This will always launch the local help by default
Hah, i was looking for the same topic but couldn't find it...
I remember there being the typo of "Inventor 2015", which you copied 🙂
Edit:
Found it, it was the post about the wikihelp retiring.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Just because... here's a link to an article on the benefits of offline help: http://beinginventive.typepad.com/being-inventive/2012/04/when-context-help-does-not-show-you-the-ri...
