Im sure this is a simple solution, but I cant figure it out. On my computer at work, if I use the offset feature (2D sketch) I get a different result than I do on my home computer. For example. If I draw a rectangle and then offset that drawing and dimension it .75, all it takes is that one dimension to constrain the entire offset. On my work computer if I offset that same rectangle, I have to go dimension each line. I can find a way to change the "rules" of that feature. Thanks
Solved by dan_inv09. Go to Solution.
Actually anytime between when you click the offset icon and when you place it you can change that.
A little tip for people learning Inventor - try right clicking, lots of good stuff is hidden there. If you think, "It would make sense that if I'm doing this I could ..." it's probably there if you right click.
