Inventor Forum
Objects not supported by iFeatures - Help!
18 REPLIES 18
Message 1 of 19
saldtch
3285 Views, 18 Replies
Hi all, I am quite new to Inventor (and I am using a friend's Inventor only...). I am trying to create a hole punch that I can extract for iFeatures. But it keeps prompting me with the Objects not supported by iFeatures message. The punched hole file is attached. Thanks in advance for the help!
Tags (2)
18 REPLIES 18
Message 2 of 19
JoAnn_Hogan
in reply to: saldtch
The iFeature command works off "features". Have you tried creating the profile and extruding it and then create your iFeature from that feature?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 19
JDMather
@saldtch wrote:
.... The punched hole file is attached. Thanks in advance for the help!
What browser are you using to try to attach?
You might try zipping the file.
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Message 4 of 19
saldtch
in reply to: JoAnn_Hogan
Thanks, I am able to extract a cut hole but now everything I drew for the hole punch unfortunately : (. I think I failed to attach my drawing. Let me try again.
Message 5 of 19
saldtch
in reply to: JDMather
Thanks let me try! I am using Chrome and I actually chose my file but it just did upload somehow 😞
Message 6 of 19
saldtch
ok it didnt work again... let me try with IE
Message 7 of 19
JDMather
1. Your Sketch(3 in this case) should have a Sketch CenterPoint.  (you have a Point - you can toggle it to a Center Point in upper right corner of screen.
This is a case were you do not want to fully constrain the sketch.  Delete the autoprojected origin center point before creating your circles.  You do not want anything tied to the feature other than a face selected on which to create the sketch.
2. in Sketch4 do not use part origin workplanes as those can't go along with the feature. (create a sketch line in Sketch3 and use that and the face to create a dependant workplane that will go with the Cut1 feature) Do not use Project Cut Edges (same reason as above - you have to be very careful about parent/child dependancies - the children must be able to go with the feature).
Message 8 of 19
saldtch
I somehow managed to extract the feature, but now it is on the wrong plane with I apply it to a sheet metal...
please help!
Thanks!
Message 9 of 19
JDMather
Open the *.ide file.
What do you see in the browser?
I need the original generating geometry.
Message 10 of 19
saldtch
Thanks for the reply!
I guess I need some time to digest it.... Smiley Indifferent
Message 11 of 19
saldtch
Sorry Sir, what do you mean by "What do I see in the browser"?
here is the screenshot:
http://s8.postimg.org/9ju5a1o7n/punch_5.png
I guess I really should buy some reference materials or even take some Inventor course, or else I will have to stick to drawing with AutoCAD...
Message 12 of 19
JDMather
What I meant is - there is nothing there to see.  Nothing to answer your question.  No way to answer your question.  So you answer should be - there is nothing in the browser except the icon for the Punch.  The only way to answer your question is to see the geometry you used (like in the first file you posted) that shows how you created the Punch.
I assume that in creating this punch you made the changes suggested in my previous response.  That is what I need to see - the exact changes that you made.
Message 13 of 19
saldtch
Sorry I am confused, I attached another file here and I just tried downloading and opening it. It shows the geomatry I have drawn.
Like this:
Let me try attaching the file again, I really don't quite get what the problem is...
If the attachment is still not shown here, please try the following link:
http://www.filedropper.com/punch5
Sorry for the inconvenience caused.
Thanks!!!
Message 14 of 19
JDMather
No apologies are needed here - that is what a help forum is for.
The *.ide file is useless to me.
Attach the *.ipt file here that you used to create the *.ide file.
Message 15 of 19
saldtch
Oh, I thought the *.ide can be opened on other computers without a problem. (Honestly Inventor is quite strange to me...)
Please find the attached *.ipt.
The problem I have is the punch tool is trying to align the sketch plane with the sheet metal plane, and I need it to be perpendicular to it...
Thanks so much for the help!
Message 16 of 19
JDMather
Sure it can be opened - but there is no useful information in the finished iFeature (Punch) to show where you went wrong in creating it.
You have not created it correctly - you were closer in your first attempt.
You must start with a Sheet Metal part Face feature (for what you are after) and then proceed very much like your original attempt, except for the 2 mistakes I pointed out earlier.  You were almost there.
I did notice another error in logic.
You made the material get thicker than it was to start with?
The outside radius should be equal to the inside radius + the thickness.  You have them both the same.
One or the other has to be different.
Message 17 of 19
JDMather
Going back to your original file
1. remove the extra circle
2. change the point to a sketch center point
2a. I recommend you give the dimension a name.
Attach your file here.  Edit: I made some changes.
Message 18 of 19
saldtch
Thanks very much for the help and understanding! Yes I haven't yet considered if that punch is logical. I will amend it! Let me really take some time to try again and learn Inventor. Just thanks a lot!
Message 19 of 19
huybtvn
I have the same problem to create iFeatures. Could anyone educate? Attached is the ipt.file
It keeps saying "Objects not supported by iFeatures will be removed from selection"
