Inventor General
Distinguished Contributor
eveylynne
Message 1 of 3 (215 Views)
Object visibility
215 Views, 2 Replies
05-03-2012 09:36 AM
I've created a swept part with oodles of user created work planes/point/axii.
I use the View Tab/Object visibility/ and toggle them all off. When I create a new object, the visibility is turned back on, so all these things are visible again.  Is there a way to tell IV that when I turn the visibility off, it stays off?
I've created a View, called Hidden, and made sure that the visibility of those three is all off.  Yet, when the part is in an assembly, several random planes/points/axii are visible.  The master is usually selected for the part whenever it appears in an assembly, but if I change it to hidden, these things are still visible.  Also, if I chose "Hidden" for the view in my assembly, I must also click "associative," or the part remains in the Master view. Regardless of which view is selected, they look the same.
I can manually turn the visibility off in whatever assembly I drop the part in, but that is tedious, and I have to do it for anyassembly the part is in.  So, if I put the part in A.iam, then put A.iam in B,iam, I have to manually turn off the visibility for all of the user created stuff in both for the part in question.
Thoughts/suggestions?
eveylynne
Message 2 of 3 (210 Views)
Re: Object visibility
05-03-2012 09:47 AM in reply to: eveylynne
As an added note, if I turn off visisbility on an axis, point, etc fomr this part while it is in an assembly, I have to remvoe associativity.  The part goes back to the master view, the objects are no longer visible.  When I change it back to "Hidden," they appear again, even though the user ccreated stuff is all not visible in the part while in the "Hidden" view.
eveylynne
Message 3 of 3 (206 Views)
05-03-2012 09:52 AM in reply to: eveylynne
& one other note. While the Object visibility is turend off in the visibility tab for the part, if i right click the feature in the tree, visibility is still checked, even though I can't see it.  If the axis is visibile in an assembly, and I turn of the visibility from the tree rather than the View menu, it will no longer be visible if the part is using the "hidden" view.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
