Inventor Forum
Object Visibility
7 REPLIES 7
Message 1 of 8
239 Views, 7 Replies
Object Visibility
I have turned the visibility off on a part in a subassembly. This sub is
used in several places throughout the main assembly. When I open the main
assembly, the part is still visible. Why is this part still visible in the
main assembly, even though it is not visible in the subassembly file?
Kirk
Inventor 7.0 sp1
Dell 4550
WinXP Pro
P4, 2.8 Ghz, 1G
Quadro 900 XGL
nVidia v6.14.10.4403
1280x1024, 32 bit
7 REPLIES 7
Message 2 of 8
did you update the main assembly?
Lloyd
Message 3 of 8
Sub-assemblies come in the main assembly with the system.all visible design view
by default. You have to create a new design view and place it using that view
(under options).
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Kirk A." wrote in message
news:AD7301CB849DEC53CAB72C625E879E90@in.WebX.maYIadrTaRb...
> Kirk
> Inventor 7.0 sp1
> Dell 4550
> WinXP Pro
> P4, 2.8 Ghz, 1G
> Quadro 900 XGL
> 1280x1024, 32 bit
Message 4 of 8
Once you create a new design view. Right click on the view in the .idw and
click apply design view. Then pick your new design view. This will keep all
your dimensions and extra info associated with the view.
Hope it helps.
Jesse
Message 5 of 8
I created a design view in the sub that had the parts turned off. Where is
"Options"??
When I go to the assembly and edit another occurence of the sub, design view
is grayed out. Attached here is a picture of what I have. I would like to
have the bars not shown, like the sub on the right. I have several of these
subs in this assembly. Only the one on the right is shown correctly.
How do I get the other subs to be displayed properly?
Kirk
"Dave Jacquemotte" wrote in message
news:C73F96FF0D27966D35F780510CAF687C@in.WebX.maYIadrTaRb...
design view
view
> (under options).
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
is
main
the
> > Kirk
> > Inventor 7.0 sp1
> > Dell 4550
> > WinXP Pro
> > P4, 2.8 Ghz, 1G
> > Quadro 900 XGL
> > 1280x1024, 32 bit
Message 6 of 8
RMB on the incorrectly displayed sub and hit Apply Design View. You should be
prompted to pick one of the views.(I was explaining how to do it at first
placement)
BTW, when you are first placing a sub into higher assembly, you can pick design
view by first, highlighting the ass'y in Place Component" dialog, then hitting
Options. (Options is grayed out until you pick ass'y) See attached for pic.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
news:DDC2FBBF49EBCF26153A5D7F508C91AE@in.WebX.maYIadrTaRb...
> "Options"??
> Thanks
> Kirk
> design view
> view
> > (under options).
> > Dave Jacquemotte
> > Automation Designer
> > www.autoconcorp.com
> is
> main
> the
> > > Kirk
> > > Inventor 7.0 sp1
> > > Dell 4550
> > > WinXP Pro
> > > P4, 2.8 Ghz, 1G
> > > Quadro 900 XGL
> > > 1280x1024, 32 bit
Message 7 of 8
Sorry, forgot to attach pic. BTW, I should have said Import Design View, not
"Apply"
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
news:428A8F0D3165ACE73EA2515C01F18188@in.WebX.maYIadrTaRb...
> placement)
design
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
> > "Options"??
> > Thanks
> > Kirk
> > design view
> > view
> > > (under options).
> > > Dave Jacquemotte
> > > Automation Designer
> > > www.autoconcorp.com
> > is
> > main
> > the
> > > > Kirk
> > > > Inventor 7.0 sp1
> > > > Dell 4550
> > > > WinXP Pro
> > > > P4, 2.8 Ghz, 1G
> > > > Quadro 900 XGL
> > > > 1280x1024, 32 bit
Message 8 of 8
Thanks Dave, using the "Import Design Views" worked great. I could have
swore that I had made changes to the visibility of parts in a sub before and
not had to do this. Must have been something else...
be
> placement)
design
hitting
pic.
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
is
> > "Options"??
view
to
these
> > Thanks
> > Kirk
> > design view
that
> > view
> > > (under options).
> > > Dave Jacquemotte
> > > Automation Designer
> > > www.autoconcorp.com
sub
> > is
the
> > main
in
> > the
file?
> > > > Kirk
> > > > Inventor 7.0 sp1
> > > > Dell 4550
> > > > WinXP Pro
> > > > P4, 2.8 Ghz, 1G
> > > > Quadro 900 XGL
> > > > 1280x1024, 32 bit
