Sorry, forgot to attach pic. BTW, I should have said Import Design View, not
"Apply"
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Dave Jacquemotte" wrote in message
news:428A8F0D3165ACE73EA2515C01F18188@in.WebX.maYIadrTaRb...
> RMB on the incorrectly displayed sub and hit Apply Design View. You should be
> prompted to pick one of the views.(I was explaining how to do it at first
> placement)
> BTW, when you are first placing a sub into higher assembly, you can pick
design
> view by first, highlighting the ass'y in Place Component" dialog, then hitting
> Options. (Options is grayed out until you pick ass'y) See attached for pic.
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
> "Kirk A." wrote in message
> news:DDC2FBBF49EBCF26153A5D7F508C91AE@in.WebX.maYIadrTaRb...
> > I created a design view in the sub that had the parts turned off. Where is
> > "Options"??
> > When I go to the assembly and edit another occurence of the sub, design view
> > is grayed out. Attached here is a picture of what I have. I would like to
> > have the bars not shown, like the sub on the right. I have several of these
> > subs in this assembly. Only the one on the right is shown correctly.
> > How do I get the other subs to be displayed properly?
> > Thanks
> > Kirk
> > news:C73F96FF0D27966D35F780510CAF687C@in.WebX.maYIadrTaRb...
> > > Sub-assemblies come in the main assembly with the system.all visible
> > design view
> > > by default. You have to create a new design view and place it using that
> > view
> > > (under options).
> > > Dave Jacquemotte
> > > Automation Designer
> > > www.autoconcorp.com
> > > news:AD7301CB849DEC53CAB72C625E879E90@in.WebX.maYIadrTaRb...
> > > > I have turned the visibility off on a part in a subassembly. This sub
> > is
> > > > used in several places throughout the main assembly. When I open the
> > main
> > > > assembly, the part is still visible. Why is this part still visible in
> > the
> > > > main assembly, even though it is not visible in the subassembly file?
> > > > Kirk
> > > > Inventor 7.0 sp1
> > > > Dell 4550
> > > > WinXP Pro
> > > > P4, 2.8 Ghz, 1G
> > > > Quadro 900 XGL
> > > > nVidia v6.14.10.4403
> > > > 1280x1024, 32 bit
