Inventor Forum
Nvidia 750 XGL
8 REPLIES 8
Message 1 of 9
230 Views, 8 Replies
Nvidia 750 XGL
I have a Quadro 4 750 XGL 128 meg card with Inventor 6 SP1. I'm using the
driver version 29.42 Autodesk recommends this and is fully certified. These
are the problems I'm having, some sketches will disappear when I'm editing
them and I will get black boxes and garbled text in some drawings. I have a
feeling it is a setting and not the card can anyone help me.
Matt Luedke
Sharp Packaging Systems
8 REPLIES 8
Message 2 of 9
Matt
Check out "pn.hardware" DG thread "PNY 750 XGL problems". You'll find a
discussion on what might be help?
>ron,
Here's what I'm using in 4103:
Select OpenGL on flyout on Quadro 4 750 xgl tab:
Enable Unified Back Buffer=on
Enable Overlays=on
Maximize Texture Memory=on
Others=off
Vertical Sync=off by default
Use up to /16/ megs in pci mode
There are also a couple of reg hacks, regarding "Gift
Wrap Tolerance" and "Min Full LOD Framerate" in Reg
(\registry version6.0\system\preferences\display) that I
haven't had a chance to compare yet. Beware, they REG_SZ's,
not DWORDS! Maybe John will get back with some
reccomendations on those?
enjoy,
>darvin
gcooper
Message 3 of 9
You might want to try a different driver - I'm using 4072 on my XP Pro
system.
I just installed it yesterday and so far no problems.
"Matt Luedke" wrote in message
news:3E35BCCF9716FBF47B904A4A058584C1@in.WebX.maYIadrTaRb...
These
a
> Matt Luedke
Message 4 of 9
Is that going to be a better driver then the 41.03? If so, what are the
improvements?
"Ron Crain" wrote in message
news:648D1809EF86FAF7D811B20D881F6230@in.WebX.maYIadrTaRb...
> system.
the
> These
editing
have
> a
> > Matt Luedke
Message 5 of 9
Ron
What kind of tweaks are you doing in the driver if any? I have been using that driver on
my Ti4600 and have been getting more Pregnant pauses than normal.
Kent
Member of the Autodesk Discussion Forum Moderator Program
> system.
> These
> a
> > Matt Luedke
Message 6 of 9
I'm using 4072 for right now because I want some history with it before I
move to 41.03
The reasoning is that when I was having problems with R6 at first release, I
was told to use 40.72 because it was the one that nVidia would modify if
Autodesk found any issues. After about a week of working with this, I'll be
trying out 41.03 to see if there is any difference. Obviously, since 41.03
is a more recent build than 40.72, there may be some advantage - but I'm
moving in a methodical pace.
"Josh Beissel" wrote in message
news:A92ED8484046F6AE0457D3D997538AA6@in.WebX.maYIadrTaRb...
> improvements?
> > system.
> the
> > These
> editing
> have
> > a
> > > Matt Luedke
Message 7 of 9
I did the OpenGL tweaks that Darvin mentioned in the pn.hardware thread
about my problems with the 750 XGL (why do "I" always have problems? ).
I don't think it made any improvements but I left them anyway.
What can I tell from the framerate display in Inventor? It seems to me that
the numbers change too quickly to be able to visually see how fast things
are going.
"Kent Keller" wrote in message
news:4E5A90514DF7FFEA3F825C1FCF34046E@in.WebX.maYIadrTaRb...
> Ron
that driver on
Message 8 of 9
ron,
The way I do it is,
Put the Engine.iam in Isometric,
Orbit and pan it out of place,
Then use RMB Isometric,
Don't move the mouse after you hit "I". When it stops
the framerate should be fixed at some value. That's the
test.
I think what's happening with these Dtonator 4 drivers,
is more stuff is being accounted for in Swaptype and
Workaround and more options are being internally defaulted
in the drivers. So any tweaks we come up with are far less
significant than they used to be.
darvin
Message 9 of 9
I get various results with your method. Too wide of a spread to put any
reliability in it.
"darvinv" wrote in message
news:801D2C605A85BEE1E52EFB9E16FC84E0@in.WebX.maYIadrTaRb...
> ron,
> The way I do it is,
> test.
> darvin
