I have a problem fo cycling dependency when I try to do a notch in a particular case.
I have this frame sample. I need to notch each frame parts. I realize 3 notchs, first one between 1 and 2, second one between 3 and 4. This two notch are realized without any problem.
When I try to do the last notch between 5 and 6 I have a cycling dependency error message. I don't understand why and how to solve the problem.
Hi Thomas
I can reproduce the issue you described, and I have logged it into internal tracking system. It will fail to create a notch treatment on each member, but it's ok to add notch treatment on one member twice.
In your experience, will you prefer to add notch treament on each member?
