Inventor Forum
Not getting material textures
1 REPLY 1
301 Views, 1 Reply
I am unable to apply textures to the maodel I made in inventor.
I tried doing it from the iproperties as well as the top down option we have on the top. Its not working.
Where as, If someone else logs-in in my system, they are able to apply.
Can anyone suggest what should be done in this case..?
HMalhotra
Tags (1)
1 REPLY 1
VinodBalasubramanian
Check whether you have set full read/write permissions for the registry keys and folders provided in the following solution.
This solution is for the Inventor uninstaller but just look for the path for those folders and registry keys and check their permissions in your login and the other working user.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
