Inventor Forum
Not able to "drag" parts in assy.
7 REPLIES 7
Message 1 of 8
slphantom
994 Views, 7 Replies
I have a sub assy. that I am rebuilding. I have some existing models and some new one's. When I apply one constraint to a model I am no longer able to "drag" that part in the remaining directions it can move. Anyone ever come across this?
thanks
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
7 REPLIES 7
Message 2 of 8
rdyson
in reply to: slphantom
Is the red Cross lit?
PDSU 2016
Message 3 of 8
slphantom
in reply to: rdyson
nay
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
Message 4 of 8
JDMather
Can you reduce to two parts, reproduce behavior and post the assembly here?
Message 5 of 8
stevec781
in reply to: JDMather
Yes I get this all the time.  Parts wont drag with just a click on it but will move if you use the move command.
Message 6 of 8
LMajors666
Message 7 of 8
stevec781
in reply to: LMajors666
Its not always a constraint problem, often its associativity thats the problem.  If you place the attached files somewhere and open the assembly you can see.  You cant free drag part2.  But if you use the move command it will move and when you rebuild, the associative hole will update correctly.
Message 8 of 8
Allen.Bai
in reply to: stevec781
It should be caused by adaptive Hole created in Part2.  In your attached case, if you mate/flush face along X and Y axis between two parts, you can "drag" move it along Z axis, because the adaptive Hole in Part2 can always be generated.
Allen Bai
Senior User Experience Designer
Design, Lifecycle & Simulation
