"Angus_McL" <Anyone
href="mailto:amclarty@brooke-ocean.com">amclarty@brooke-ocean.com>
wrote in message
href="news:f12dd0d.-1@WebX.maYIadrTaRb">news:f12dd0d.-1@WebX.maYIadrTaRb...
out there come across Nord-Lock vibration-proof washers as i-parts?
Angus
"Angus_McL" <Yeah,
wrote in message
href="news:f12dd0d.1@WebX.maYIadrTaRb">news:f12dd0d.1@WebX.maYIadrTaRb...
I checked there first.
The washers come as pairs, with mating wedges on one side, and radial teeth
on the other. You install the pair with the wedges interlocking so that as you
increase bolt tension the wedges lock together and prevent the fastener from
vibrating loose.
They are in the McMaster-Carr and Spaenaur cataloges as well as others.
Maybe I'll check the M-C website to see if the have dummy solids of the
washer pairs to download.
Angus
I worked for Nord-Lock and now work for a German company that has a lower cost equal called Heico-Lock. I have files if you need them.
Kerry
Actually if you have any I wouldn't mind. I need Nord-Lock washers to put in our content centre. Well - it doesn't have to be the brand, just that style of washer
another question not directly related to the ipart question, I would think that the part would be made of 2 washers, how do i call that up in the BOM as 2 washers and not just 1 part? I dont really want to be putting them in seperatly because they are always going to be installed as pairs
Stephen,
Please find attached.
I like it, it adjusts nicely - though there are a lot of features to it. I'm just wondering if 100+ are used is it going to take up a load of memory in comparison to my (very basic looking) simple model?
Hands down, for looks, yours wins!
Did you make two different families based on the different materials? Have you added the specific materials Nord-Lock use to your library?
Will have to see if the features slow down a large assembly... We only use 316L because everything is marine, I have created a load of other standard fastener content though and used the 'material guide' 'add material as new family members', you choose the material as you are placing the part, seems to work ok
