Inventor Forum
No text shows using hole annotation tool in inventor 2011
3 REPLIES 3
ihiengdept
556 Views, 3 Replies
I'm using inventor 2011.  I'm creating a drawing for a part, and when I attempt to annotate a hole, no text shows up.  Just a blank leader line.  The hole is a thru hole, but when I change it to another type, (like "distance" or "to") it will give me the text.  So what am I missing?  I've made other parts where I don't have this issue, but nothing works recently.
3 REPLIES 3
jeanchile
in reply to: ihiengdept
This may be a stupid question but I'm gonna' ask it anyway: Have you looked at your style library to make sure the note for a thru hole hasn't been edited/deleted? I've never encountered this issue, it's just the first thing I though of.
Inventor Professional
SBix26
When you edit the blank thru hole note, what do you see?  You should see something like this:
<QTYNOTE>Ø<HDIA> THRU.  If not, your style library and/or template needs some remediation...
ihiengdept
in reply to: SBix26
Things got busy and it took me a while to get back this, but both replys were right on.  Somehow that one definiton for a THRU hole got completely deleted in the style library for a template I was using.  I'm still fairly new to autodesk so I really appreciate the help.
Thanks!
