I tried to do a stress analysis on a simple rectangular part today but after pressing the "simulate" button, no results showed. Interestingly enough, I tried this on another computer and it worked perfectly. Following another thread, it was clear that other people are having the same problem. It seems like there has been no solutions so far. I tried reinstalling, but that didn't help either. Any ideas?
The part for stress analysis has been attached.
Solved by JDMather. Go to Solution.
Your part works fine on my machine.
The first step might be to install Service Pack 1 and Update 3 for SP1.
Make sure you turn off UAC during the install, and I don't see any mention of your OS in your problem description.
Thanks, that worked. For future references to people who may be reading this- I am running 64 bit Windows 7. I installed update pack 1, 2, and then 3. After that, the results show up.
Hi
I dont get any results from stress analysis after I have clicked on solve? Have tried the part on another computer and it works there? OS is Windows 8.1
