I am putting balloons on an assembly drawing, but the circle is not appearing. The arrow, leader and number are there, but no circle. What could be wrong?
Solved by jletcher. Go to Solution.
Well I don't know you don't explain or tell us anything. What is your style of balloon set to is it set to show a circle? If so then a version of Inventor would be nice so those that had an issue with balloons will know if it is the same issue they had and can tell you how they fixed it.
