Inventor General
Valued Contributor
eric.mathews
Message 1 of 2 (531 Views)
Accepted Solution
No Vault Tool bar 2013.
531 Views, 1 Replies
10-19-2012 06:47 AM
I recently installed Vault pro 2013. I was running Inventor 2012 at the time.. My vault add-in stopped loading. I installed Inventor 2013 and the vault add-in still won't load. I've gone to the Add-in manager 2013 and set it to loaded. I hit the "OK" button and nothing. Open the manager up again and it says "unloaded". Something is going on that is not allowing my vault add-in to load. This is very frustrating. Any suggestions?
Product Support
Message 2 of 2 (506 Views)
Re: No Vault Tool bar 2013.
10-22-2012 06:20 AM in reply to: eric.mathews
Have you tried changing the Vault Client from Programs and Features?
  1. Right click on the Vault Client and select Change.
  2. Now select Add / Remove Features.
  3. Un-check the Add-in for Inventor.
  4. Update.
  5. Now go back and this time check the option to add the Add-in.
  6. Update.
Hopefully this should work OK.
Jon.
Jon Dean
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
