Inventor General
*Howard, Jeff
Message 1 of 10 (252 Views)
No RTTI data....
252 Views, 9 Replies
11-14-2002 07:15 AM
crash. See CF "No RTTI data (IV6).
Initiate loft command.
Pick profiles: sketches 11, 12, 15.
Pick rails: sketches 13, 16, 14
Go to Transitions tab and clear Automatic checkbox.
Crashed 5 out of 6 times for me. Also crashed in the original file the
sketches were derived from.
Jeff
*Caldwell, Larry
Message 2 of 10 (252 Views)
Re: No RTTI data....
11-14-2002 07:53 AM in reply to: *Howard, Jeff
Jeff, need the parent file to go with the derived part. It is looking for
Surfaces U & V when I try to open it and yours is different than mine.
~Larry
"Jeff Howard" wrote in message
news:9F96604BC4BA45504E67C14EE9B691C6@in.WebX.maYIadrTaRb...
> Jeff
*Howard, Jeff
Message 3 of 10 (252 Views)
Re:
11-14-2002 01:30 PM in reply to: *Howard, Jeff
You should be able to put my file in a directory or project where it can't
find your version of Surfaces U & V and Skip All when loading it (at least
that's what I did, should have broken the link before sending). My file will
look slightly different than your original, I'd made some small changes and
projected geometry to create the new rail sketches.
Interested to see if it's reproducible or just my system being cantankerous.
"Larry Caldwell" wrote in message
news:257ED1F82099A0BA231B961BB3CA162E@in.WebX.maYIadrTaRb...
~Larry
> Jeff
*Yeandle, Laurence
Message 4 of 10 (252 Views)
Re:
11-14-2002 05:37 PM in reply to: *Howard, Jeff
Hi Jeff, crashes here too, don't now anything about surfaces other than
looking at your stuff. The model solves quite easily if you loft from 12 to
11 and 11 to 15 using two lofts, the inclusion of the rails in lofts does
nothing it appears and trying to loft three sketches at once fails without
the rails as well. You can use the rails on loft 11 & 12 OK but rails on the
11 & 15 fails. I would have thought that the rails were not needed at all
seeing that the shapes are similar? And failure of 11 & 15 with rails might
be due to the orientation of the sketches at 90o ? But what do I Know,
Autodesk will no doubt shed some light.
Laurence,
Power is nothing without Control
news:6C928D0B4867B80953C703658626C3E0@in.WebX.maYIadrTaRb...
will
and
cantankerous.
> ~Larry
> > Jeff
*Howard, Jeff
Message 5 of 10 (252 Views)
Re:
11-14-2002 07:04 PM in reply to: *Howard, Jeff
Thanks for looking, Laurence.
The sketches are from Larry's file related to the Shape Manager Unmanagable
thread, where Larry and I demonstrated how little we know about the subject
8~). I was playing with it when IV so rudely dumped me on the roadside.
Have a good one,
Jeff
"Laurence Yeandle" wrote in message
news:3B6EBAC3D6FE8B900BF7D74B639C940F@in.WebX.maYIadrTaRb...
Hi Jeff, crashes here too,.......
*Yeandle, Laurence
Message 6 of 10 (252 Views)
Re:
11-14-2002 08:56 PM in reply to: *Howard, Jeff
Oh if I'd have known it was one of Larry's fumble's I wouldn't have bothered
I suppose that loft is the only chance of some sort of compound curve
you wish to get on the stern of the tub, I need to look into this in 6.0 and
how it controls shapes. From what I gather 5.3 points were to control twist
in model, are you trying to control the curve of (contour path ) on hull to
give a realistic shape is that what rails are supposed to do? I feel that
compound surfaces in IV will remain illusive still or can this be done or
will any package handle this, similar to a 3d sweep?
Laurence,
news:613938EA3C81BE7D94CC56F0F1EA442D@in.WebX.maYIadrTaRb...
Unmanagable
subject
> Have a good one,
> Jeff
*Caldwell, Larry
Message 7 of 10 (252 Views)
11-14-2002 08:58 PM in reply to: *Howard, Jeff
Yep ... no rtti-ditti ... just like you. Won't even give you a chance to try
to change it. I saw a post saying what RTTI meant but can't find it. I don't
think the post had the acronym, just the words so that's probably why a
message search on RTTI doesn't turn it up. Maybe someone remembers.
~Larry
> Jeff
*Caldwell, Larry
Message 8 of 10 (252 Views)
Re:
11-14-2002 09:22 PM in reply to: *Howard, Jeff
Ah ... but now you know!
~Larry
news:A687E1E52E058DB62E5A224B1E82B581@in.WebX.maYIadrTaRb...
bothered
curve
and
twist
to
> Laurence,
> Unmanagable
> subject
> > Have a good one,
> > Jeff
*Autodesk\
Message 9 of 10 (252 Views)
11-15-2002 03:27 AM in reply to: *Howard, Jeff
I logged a defect against it.
Loren Jahraus
Autodesk Inventor Workflow Team
> Jeff
*Howard, Jeff
Message 10 of 10 (252 Views)
Re:
11-15-2002 04:45 AM in reply to: *Howard, Jeff
Many thanks, Loren.
"Loren Jahraus (Autodesk)" wrote in message
news:502669F952FE61610BB7BE042215EC85@in.WebX.maYIadrTaRb...
Loren Jahraus
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
