Hi Jeff, crashes here too, don't now anything about surfaces other than
looking at your stuff. The model solves quite easily if you loft from 12 to
11 and 11 to 15 using two lofts, the inclusion of the rails in lofts does
nothing it appears and trying to loft three sketches at once fails without
the rails as well. You can use the rails on loft 11 & 12 OK but rails on the
11 & 15 fails. I would have thought that the rails were not needed at all
seeing that the shapes are similar? And failure of 11 & 15 with rails might
be due to the orientation of the sketches at 90o ? But what do I Know,
Autodesk will no doubt shed some light.
Laurence,
Power is nothing without Control
"Jeff Howard" wrote in message
news:6C928D0B4867B80953C703658626C3E0@in.WebX.maYIadrTaRb...
> You should be able to put my file in a directory or project where it can't
> find your version of Surfaces U & V and Skip All when loading it (at least
> that's what I did, should have broken the link before sending). My file
will
> look slightly different than your original, I'd made some small changes
and
> projected geometry to create the new rail sketches.
> Interested to see if it's reproducible or just my system being
cantankerous.
> "Larry Caldwell" wrote in message
> news:257ED1F82099A0BA231B961BB3CA162E@in.WebX.maYIadrTaRb...
> Jeff, need the parent file to go with the derived part. It is looking for
> Surfaces U & V when I try to open it and yours is different than mine.
> ~Larry
> news:9F96604BC4BA45504E67C14EE9B691C6@in.WebX.maYIadrTaRb...
> > crash. See CF "No RTTI data (IV6).
> > Initiate loft command.
> > Pick profiles: sketches 11, 12, 15.
> > Pick rails: sketches 13, 16, 14
> > Go to Transitions tab and clear Automatic checkbox.
> > Crashed 5 out of 6 times for me. Also crashed in the original file the
> > sketches were derived from.
> > Jeff
