In the past, BOM's were not created in AutoDesk. They were created in our MRP program. That program is changing and we will no longer be able to create BOM's in our MRP program. So, moving forward we will use Inventor to create and maintain BOM's....no problem there. The problem is that we have 1000's of 2-D drawings with BOM's structured in the MRP program. I have no idea how to get all of those parts in Inventor (without re-drawing all of them). Since we will be using Inventor for revision control, any parts drawn in 2-D with the MRP BOM will no get updated when we update a component in inventor.
So I need a consultant. I am not familar enough with Inventor to figure this out. I do not need a reseller!
Thanks!
Brian
If I'm reading that right you are moving from a 2D drafting environment to Inventor 3D environment. If that is true then you will need to recreate the models in Inventor. The MRP issue sounds secondary to that.
Or am I misunderstanding you?
Hi jcosta,
You might be able to use AutoCAD Mechanical to add an intelligent BOM to your existing 2D drawings. Can you post a typical example(s) of the type of drawings you're working with? Or at least screen shots of the drawings maybe?
I hope this helps.
Curtis
Brian,
Can you possibly clarify a few things?
My basica understanding is you have a bunch of 2D drawings with the BOM's created and controlled by the MRP that is no longer being used. You now want to take these BOM's and place them onto the Inventor 2D drawing? What are these 2D drawing made in? AutoCad? Are you in need of converting these 2D drawings into Inventor?
Please contact me by way of the email in my signature. I can help you out either by walking you through this process or if need be, having a few people take care of this for you.
