Hi
We're using semi-isolated project type and my PC keeps creating .newver. files when I check models back into the shared 'workgroup' folder. When it happens (maybe 10% of check-ins) I get an error message saying file is locked by another process, but as far as I can see there are no other processes that should be accessing the file either on my PC or the server where the workgroup folder lives.
No one else using the workgroup/project is having this issue and we're all using Autodesk Inventor 12.0 SP3.
Anyone come across this before? It's only started happening recently and my setup hasn't changed in two years.
Jon C.
Hello Cnoj
.Newver files appear when having trouble while saving. If you're the only computer having this problem, you should check :
Thanks.
