Inventor Forum
Newby Question
4 REPLIES 4
86 Views, 4 Replies
Newby Question
Probably first of many!
I extruded a u-channel as a surface. Three lines, one horizontal, two
vertical.
I then thickened it to create my part, both sides. I try to create a sketch
on any of the three inside surfaces. The sketch plane jumps to the outside
surface. OK, no problem I can create a work plane us two edges and use it
for my sketch. This works so I add another part starting with one of my new
work planes. Finish the part, further constraining it to the work planes.
I now edit a part feature, update the part, update the assembly. I now get
an error message telling me all of my constraint are trashed.
Obviously my problem started with the thickened surface, but what am I
missing? Shouldn't this approach have worked?
Ray
4 REPLIES 4
I seldomly use the thicken command, but it sounds like it should have
worked. If I was going to make a "U" channel, I would sketch the profile (8
lines, 4 vertical, 4 horizontal) then extrude.
"Ray Dyson" wrote in message
news:35D6EE5886255E43D19B69689C09F76B@in.WebX.maYIadrTaRb...
> vertical.
sketch
new
> Ray
Thickened mid surfs is the method I use for sheet metal frames, etc. in other
apps. I had the same experience trying to use it in IV. Bummer.
> vertical.
> Ray
It only occurs when you use the bi-directional option during thicken. I
logged a defect against this.
Loren Jahraus
Autodesk Inventor Workflow Team
> vertical.
sketch
new
> Ray
Thanks Loren and all!
Good to know it wasn't just me. And , yes I'd probably never use this for so
simple a part, just kicking tires.
Ray
"Loren Jahraus (Autodesk)" wrote in message
news:F1D6026E8BC159E24128E4FA714B53F9@in.WebX.maYIadrTaRb...
> Loren Jahraus
> > vertical.
> sketch
outside
it
> new
planes.
get
> > Ray
