Inventor General
Valued Contributor
boilerchip
Message 11 of 25 (52 Views)
Re:
11-25-2002 08:54 PM in reply to: slightlyagitatedwookie
I haven't used steel creator, but when we got inventor this spring, two of us spent about half a day creating one foot sections of all of the standard material we use...flats, tubes, angles, I-beams, c-channel, u name it. They are all "templates" in a material folder. Now whenever we need a certain material, we go find it and save as. I haven't thought about it since. I personally think iparts are for the birds. I just don't like to have one more file to make sure never gets lost.
*Streich, Keith
Message 12 of 25 (52 Views)
Re:
11-25-2002 10:10 PM in reply to: slightlyagitatedwookie
It's listed under 9-06-02.
That  file doesn't seem to be there
anymore.
I know there was a nice little program someone
created called "Steel Creator" which runs with Inventor.  It's on
Sean's site.
href="http://www.sdotson.com/">http://www.sdotson.com/
Keith
I've
searched all the posts in this NG and haven't found anything like this. My
aplogies if this has already been covered.
Our company uses mostly
steel shapes. I would like to set up an ipart (I think?) to be able to
bring them into an assembly and input the length but then become adaptable
also (for easy revisions). I would like to have the following items shoe
up in my parts list: Itm, Qty, Description (W6"x15# for example)
Length,Mass.
So far I have dwonloaded a few iparts of steel shapes from Charles
bliss' site. I have managed to get it use the "Length" parameter in the
parts list. I'm stuck trying to get the description.
If I can figure out one shape, then it will be easy to do the same for
the others.
Thanks in advance for any help.
Heath
Active Member
Message 13 of 25 (52 Views)
Re:
I've looked as well and could not find it. (steel creator)
Sean, I've already manged to get the custom length property to appear in my parts list. It's the description that I can't get to show up. I'm using the wide flange ipart from Charles Bliss' site. In the "weight" column it has "size" and "weight" as a concatenated value. This is the value I wish to display in my parts list.
Jim was it? (sorry if incorrect)
I was trying to download the demo version of PowerSteel as suggested but lost my connection. I'm going to try again. This software does sound like it does exactly what we want it to do. However it doesn't say if the demo is compatible with R6. I'll try it anyway.
Thanks all for the help, I'll keep you all posted
Heath
*Streich, Keith
Message 14 of 25 (52 Views)
Re:
11-25-2002 10:24 PM in reply to: slightlyagitatedwookie
Right off Sean's
Site:
9/6/02 - Dave Adams has written an add on for
Inventor entitled "Steel Creator" that creates steel sections, pipes, channels
etc. It's pretty handy. I have agreed to host it for him on this site. Until I
can get a proper page in place this news item will suffice.
href="http://www.steelcreator.com/">Screenshot & Description
href="http://www.sdotson.com/vba/Steel%20Creator%20v2.zip">Download
. Note:
It was recently discovered that this program has a problem running on Windows
XP. It will run once but the second time you try to run the program it will not
load. David Adams has been made aware of this issue and I will be sure to report
when the problem has been corrected. UPDATE:9/12/02: A
new version has been uploaded that is both smaller and appears to work on XP.
You can use the same link above to download
it
UPDATE:9/17/02:Another vesrion (v2.0) has replaced the older
version. It now allows the creation of parts into a user library. Use the same
links above to download.
I've
Heath
*Streich, Keith
Message 15 of 25 (52 Views)
Re:
11-25-2002 10:26 PM in reply to: slightlyagitatedwookie
I could have posted this earlier, but wanted
everyone to visit Sean's site since it has a wealth of
information.
Active Contributor
murraysmith
Message 16 of 25 (53 Views)
Re:
11-25-2002 11:01 PM in reply to: slightlyagitatedwookie
Boilerchip:
I have to agree with your opinion. To me, it just seems like a more consistent way of handling parts: no external files are required. There are also advantages in that code can be added to the template to automate other processes as well.
Just curious, but how much space does your template directory take up? Also, would you be willing to share these files?
Murray
*Dotson, Sean
Message 17 of 25 (53 Views)
Re:
11-25-2002 11:02 PM in reply to: slightlyagitatedwookie
Thanks <g>
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
information.
Distinguished Contributor
pquenzi
Message 18 of 25 (53 Views)
Re: New user- How should I handle standard steel shapes?
11-26-2002 03:30 AM in reply to: slightlyagitatedwookie
I haven't seen this mentioned in any of the replies, but I use iFeatures for this type of thing. I think iFeatures are under rated. You can do some neat things withs them. It is just like having a parametric 3d block in Autocad. Just draw the shape your interested in, rename the variables to things like "web thickness", "height" etc. and make it an iFeature. When you insert the iFeature into an assembly you can modify any of the variables at will, drill holes in it or whatever you want.
Phil
*Estabrooks, David
Message 19 of 25 (53 Views)
Re:
11-26-2002 10:25 AM in reply to: slightlyagitatedwookie
Thanks I missed that!
It's listed under
9-06-02.
shastu
Message 20 of 25 (53 Views)
Re:
12-05-2002 12:59 AM in reply to: slightlyagitatedwookie
I am curious boilerchip as to exactly how you are using your "templates". I am assuming that you never make your parts in assembly mode, but rather make your parts in part mode and then bring them into your assembly. Or is there a way you can build your parts in assembly mode using the save as theory?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
