Inventor General
Member
allix.k
Message 1 of 5 (189 Views)
New to Inventor and need help with Flat patterns
189 Views, 4 Replies
11-20-2012 11:12 AM
I am having difficulties creating a creating a sheet metal part in Autodesk Inventor to be able to create a flat pattern. I attached a PDF of the part I'm trying to create. The first page is the item I am trying to create. The next page are the 2 pieces I've been able to construct in Inventor but I can't seem to figure out a way to make it together. I also attached the Inventor model I was able to create.
How do I create this?
I am using Inventer 2013
Valued Mentor
IgorMir
Message 2 of 5 (153 Views)
Re: New to Inventor and need help with Flat patterns
11-20-2012 04:19 PM in reply to: allix.k
Hi Allix,
Try this one. Please see the attached.
Best Regards,
Igor.
Web: www.meqc.com.au
Member
allix.k
Message 3 of 5 (150 Views)
11-20-2012 04:27 PM in reply to: IgorMir
Thats pretty close to what I need. Is there a way to close the corners though?
Valued Mentor
IgorMir
Message 4 of 5 (145 Views)
11-20-2012 04:32 PM in reply to: allix.k
Probably. Try to experiment with it. But I personally don't see a problem with it. It is not a big deal to weld them up.
Igor.
Member
allix.k
Message 5 of 5 (141 Views)
11-20-2012 04:39 PM in reply to: IgorMir
Ok. I will try. Thanks!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
