Inventor Forum
New file icon issue
4 REPLIES 4
MattH_Work
1023 Views, 4 Replies
New file icon issue
When using DWG as the default drawing filetype, I am missing the icon in the new file drop down
Not a show stopper, but should be an easy fix...
Inventor  Professional 2013, 64bit, Factory Ultimate
Win7 SP1
MattH
Product Design Collection 2025
Vault Pro 2025
4 REPLIES 4
-niels-
in reply to: MattH_Work
Do you have a template named "standard.dwg" in the same file location as the other "standard" files?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
MattH_Work
I jhave both Standard.IDW & Standard.DWG in my Template location.
In fact, I have been using the DWG template since installing 2013. The template works, Inventor just doesn't show the icon
MattH
Vault Pro 2025
-niels-
I switched to .dwg (usually use idw) to try, but the icon shows for me.
Maybe reboot, or check if project points to the proper location.
Hope you can get it fixed, i hardly use that dropdown so i don't know too much about it.
Niels van der Veer
The Netherlands
3DAli
Same problem for me,
once I switched to dwg format in application settings under drawing tab, it screwed the icon the same way you have illustrated up there. to double check, I switched back to idw and it fixed it. so obviously a bug or something, not a show stopper but nice to have the icon back.
Thanks for your support
Sincerely
Ali
Signature_Small
