Inventor General
Valued Contributor
Message 1 of 5 (243 Views)
New file icon issue
243 Views, 4 Replies
05-24-2012 03:05 AM
When using DWG as the default drawing filetype, I am missing the icon in the new file drop down
Not a show stopper, but should be an easy fix...
Inventor  Professional 2013, 64bit, Factory Ultimate
Win7 SP1
-niels-
Message 2 of 5 (242 Views)
Re: New file icon issue
05-24-2012 03:08 AM in reply to: MattH_Work
Do you have a template named "standard.dwg" in the same file location as the other "standard" files?
Using IV2014 Pro SP1 update 1, Win7-64bit
Valued Contributor
Message 3 of 5 (239 Views)
05-24-2012 03:11 AM in reply to: MattH_Work
I jhave both Standard.IDW & Standard.DWG in my Template location.
In fact, I have been using the DWG template since installing 2013. The template works, Inventor just doesn't show the icon
-niels-
Message 4 of 5 (237 Views)
05-24-2012 03:16 AM in reply to: MattH_Work
I switched to .dwg (usually use idw) to try, but the icon shows for me.
Maybe reboot, or check if project points to the proper location.
Hope you can get it fixed, i hardly use that dropdown so i don't know too much about it.
Valued Contributor
Message 5 of 5 (190 Views)
07-03-2012 07:36 PM in reply to: MattH_Work
Same problem for me,
once I switched to dwg format in application settings under drawing tab, it screwed the icon the same way you have illustrated up there. to double check, I switched back to idw and it fixed it. so obviously a bug or something, not a show stopper but nice to have the icon back.
Thanks for your support
Sincerely
Ali
Warm Regards
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
