I am just learning Inventor. I am building a fairly simple assembly where there is a hinged door that uses a gas spring to help open it (think a car hatchback). I have built the door frame and have imported the gas spring from McMaster-Carr. I can put the spring together so that the piston moves in and out and the ends can pivot about the balls.
However, when I insert the gas spring into my asembly, I cannot make it work. I am using an Insert contraint to insert the pivot balls into their corresponding mounting holes on the door frame. But I keep getting "Inconsistent Constraint" errors.
I have tried to assemble this every way I can think of and nothing seems to work.
I'm sure this is just a stupid newb error but I cannot figure it out.
HELP!!!
@ac_sheldon wrote:I am just learning Inventor.
An assembly file (*.iam) is nothing more than a list of hyperlinks and a record of assembly constraints and a bit more.
You must include the part files (*.ipt) with any assembly.
Sorry - like I said - new user.
What is the best way to attach the file so you can see it? There are bunch of part files in the assembly.
How many of the parts are actually needed to demonstrate the behavior (likely not all).
Put in a folder and right click on the folder and select Send to Compressed (zipped) folder and then attach the resulting *.zip
or
File>Save Copy As>Pack and Go
Thanks for the reply. I actually finally got it to work late last night. I guess it was just a matter of selecting the correct part of the ball joint to connect to.
I appreciate your response and now I know how to attach files!! I'm sure this won't be my last question!!
