Inventor Forum
New Sheets & Sketched Symbols
2 REPLIES 2
266 Views, 2 Replies
My .idw files will have multiple sheets.  As I
add sheets, I need the revision block to appear on the sheet as well.  As
far as I can tell, there's no way for sketched symbols to automatically appear
on a sheet... for each sheet I add, I would have to add the revision block
manually, and populate the fields each time.
Am I right?  Is there a way to do this I'm not
aware of?
Thanks...
Brian
2 REPLIES 2
problem semi-solved.  I made the revision
block (header and initial revision) part of the border.  It should
work.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I add sheets, I need the revision block to appear on the sheet as well.
As far as I can tell, there's no way for sketched symbols to automatically
appear on a sheet... for each sheet I add, I would have to add the revision
block manually, and populate the fields each time.
not aware of?
Thanks...
Brian
That's correct.  By adding them to the
titleblock or border (as you did) you can have them appear in each
sheet.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
not aware of?
Thanks...
Brian
