I am working in IV R2010, and I need to create a new material. I went to the "Help" file, and the first thing it says in "On the ribbon, select the 'Design' tab..." Unfortunately, I don't have a "Design" tab. What am I doing wrong, and more imprtantly, how do I make a new material? Because of the nature of our work here, I only use most of Inventor's features rarely, like about once every couple years, and my one remaining memory cell is usually busy remembering something else... bummer...
Solved by JDMather. Go to Solution.
While in a part file *.ipt click on the Manage tab and the Styles Editor.
You should be able to figure it out from there.
The CADWhisperer YouTube Channel
