Inventor General
*Jim Tippett
Message 1 of 3 (70 Views)
New Error: "The handle is invalid"
70 Views, 2 Replies
07-20-2004 02:03 PM
For various reasons (thank you Mr. Gates) I had to reinstall the operating system (Windows XP). I started with an fdisk and proceeded installing windows xp with all service packs. I then went about installing the rest of the programs I use on a regular basis including R8 SP1. When I attempted to open a file I got the following error: "The handle is invalid". In our office we have reinstalled the operating system on several systems and never seen this error. The hardware is a 2Ghz AMD 2600 running on 1.25gb RAM. Assuming a bad install I went down the path of fdisk, formatting and installing the operating system again, still the same problem. Any ideas would be much appreciated.....
*Karl Maas
Message 2 of 3 (70 Views)
Re: New Error: "The handle is invalid"
07-22-2004 06:03 AM in reply to: *Jim Tippett
so, you can start Invenyor fine but you can't open ANY R8 file? not even the samples that come with IV? What about a new file? K "Jim Tippett" wrote in message news:40fd8868$1_2@newsprd01... > For various reasons (thank you Mr. Gates) I had to reinstall the operating > system (Windows XP). I started with an fdisk and proceeded installing > windows xp with all service packs. I then went about installing the rest of > the programs I use on a regular basis including R8 SP1. When I attempted to > open a file I got the following error: "The handle is invalid". In our > office we have reinstalled the operating system on several systems and never > seen this error. The hardware is a 2Ghz AMD 2600 running on 1.25gb RAM. > Assuming a bad install I went down the path of fdisk, formatting and > installing the operating system again, still the same problem. Any ideas > would be much appreciated..... > >
ir555
Message 3 of 3 (70 Views)
11-12-2004 07:18 AM in reply to: *Jim Tippett
Did you ever find a solution to this problem - or find out what was causing it.
I currently have the same problem and need to fix it asap!
Regards
Danny
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
