Working in a Master sketch project and changed one of the top level master sketches.
Tried to update the top level assembly and it hung and I had to shut it down with TM.
Been working my way through files and finally found the culprit. It just plain won't
update. It wouldn't surprise me if features failed on it from the changes I made to the
top level master sketch, but usually that is all that happens......features fail and it
tells you so. This just plain won't update.
Anyone seen this before? Guess I will roll the eop marker up and see if it will do it
then.
Kent
Member of the Autodesk Discussion Forum Moderator Program
