Inventor General
Member
Message 1 of 6 (280 Views)
Accepted Solution
Network License Error
280 Views, 5 Replies
07-13-2012 02:59 AM
Hi All,
Hope someone can explain to me following error:
Requests from the same USER/HOST do not consume a new license
We had an other license server running before but that one crashed today:-(.
I register the license again and us it on a other license server we already had running for Autodesk Vault
Below the error:
Diagnostics
FLEXnet diagnostics on Fri 7/13/2012 11:57
License file: C:\Program Files\Autodesk Network License Manager\Vault2012\VLTWG_Invento_2012.lic
"85752VLTWG_2012_0F" v1.000, vendor: adskflex
  License server: DE-S-NL0147
  floating license  starts: 1-jan-1990,  no expiration date
This license can be checked out
"85796PDSU_2012_0F" v1.000, vendor: adskflex
The user can't use inventor now:-(.
*Expert Elite*
DarrenP
Message 2 of 6 (269 Views)
Re: Network License Error
07-13-2012 06:11 AM in reply to: melzenaar
post the status inquiry
what error messge is the user getting when the user launches inventor?
*Expert Elite*
Curtis_Waguespack
Message 3 of 6 (259 Views)
07-13-2012 08:59 AM in reply to: melzenaar
Hi melzenaar,
You might also search for an answer or post this question to the Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
Message 4 of 6 (242 Views)
07-15-2012 11:33 PM in reply to: Curtis_Waguespack
Hi All,
I think I have to be more patient next time, Inventor works now :-)
Perhaps there is some time between before the license becomes active.
I'm still wondering what this message means:
Thanks for all your help
Michel
*Expert Elite*
TravisNave
Message 5 of 6 (229 Views)
07-16-2012 11:00 AM in reply to: melzenaar
It means that if the same user or computer launches an additional copy of the software, it will not take another license.  Thus if you have two copies of Inventor 2013 launched, you still only use one seat.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
Message 6 of 6 (210 Views)
07-17-2012 06:10 AM in reply to: TravisNave
Thanks, now I understand.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
