Inventor General
*Martin, Lester
Message 1 of 19 (82 Views)
Need skeleton modeling tips
82 Views, 18 Replies
10-28-2003 06:19 AM
I am new at skeleton modeling and any tips would be helpful.
How do keep your skeleton from getting so big, that you its hard to read any
numbers, keep the lines apart (different colours would be nice)and getting
slow.
Lester Martin
Reist Industries Inc.
Toll Free: 1-888-565-5587
pH.: 519-669-1501
Fax: 519-669-3021
E-mail: lester@reist.on.ca
Distinguished Contributor 3dr
3dr
Message 2 of 19 (82 Views)
Re: Need skeleton modeling tips
10-28-2003 06:19 AM in reply to: *Martin, Lester
Seans site "sdotson.com" has a good tutorial I believe that is where I got it from.
*Keller, Kent
Message 3 of 19 (82 Views)
10-28-2003 06:39 AM in reply to: *Martin, Lester
You aren't trying to do it all in one sketch are you? Break it up into multiple sketches
that you can turn on and off.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Lester Martin" wrote in message
news:42291A1655B40D61316425E01D4486D0@in.WebX.maYIadrTaRb...
> slow.
> Lester Martin
> pH.: 519-669-1501
> Fax: 519-669-3021
*Martin, Lester
Message 4 of 19 (82 Views)
Re:
10-28-2003 09:08 PM in reply to: *Martin, Lester
Yes I have everything in one sketch. =(
The reason is and hopefully you can help me out here,
1 The whole sketch has to grow and shrink with each other.
2 I can't measure from one sketch to another with out projecting the line.
3 If I go into the top sketch all the sketches below disappear, and I need
to see them.
like I said I'm new at skeleton modeling, and I'm sure there are answers for
all of my problems.
*Caldwell, Larry
Message 5 of 19 (82 Views)
Re:
10-28-2003 10:01 PM in reply to: *Martin, Lester
Master sketches usually require some planning ahead but in the situation you
mentioned about needing lower-level sketch geometry in the top-level sketch,
you can copy/paste the lower-level geometry into the top-level sketch when
necessary.
~Larry
news:142BDA379BD3EB1354A4732D1A74649B@in.WebX.maYIadrTaRb...
line.
need
> to see them.
for
> all of my problems.
*Yeandle, Laurence
Message 6 of 19 (82 Views)
Re:
10-28-2003 10:20 PM in reply to: *Martin, Lester
Bit difficult to imagine exactly what you are doing without guessing, can
you post the file?
To minimise the amount of information in a sketch try using more
construction geometry and constraints?
Make your sketch1 your base sketch which will include general overall
geometry and dims.
Then for additional features in sketch2 project only basic controlling
geometry and or use equations (link dimensions by selecting them from your
sk1 whilst in sk2 :- edit dim-select drop down arrow-measure-select ref dim
and add equation as necessary)
Use offset planes from origin geometry.
Make heavy use of origins for constraining sketches etc.
Rename sketches planes axis points with a meaningful name.
Doing this means you can link any thing from your base sketch and control
the whole model as desired / required and studying the browser is easier
than opening the sketch to see its contents.
It would be nice to colour sketches for better clarity but I normally make
all or as required sketches visible then in an iso view you can study
construction of model as well AS editing any sketch dimensions.
Laurence,
Power is nothing without Control
line.
need
> to see them.
for
> all of my problems.
*Keller, Kent
Message 7 of 19 (82 Views)
Re:
10-29-2003 12:36 AM in reply to: *Martin, Lester
With Master sketching I do a fair amount of projecting lines (actually I generally try to
project line endpoints so as to keep the clutter down.) to new sketches.
Your item 3 is no different than what you would run into editing a top feature in a part.
Approach your Master sketch the same way you would build a single part. The first few
sketches should be the base for your part that everything uses to grow and shrink from.
Kent
Assistant Moderator
> to see them.
> all of my problems.
*Martin, Lester
Message 8 of 19 (82 Views)
Re:
10-29-2003 01:33 AM in reply to: *Martin, Lester
I sent file to customer files.
Thanks for your tips and Larry and Kents as well.
They would mean nothing to me if I hadn't tried it before.
Its going to be nice once I get on to this skeleton modeling.
*Keller, Kent
Message 9 of 19 (82 Views)
Re:
10-29-2003 02:56 AM in reply to: *Martin, Lester
Lester
Don't have a lot of time to look at it right now, but the first thing I see is .... why
are you using constraints in the assembly?
You might try using the insert and fix macro on my site.
http://www.mymcad.com/KWiK/mcad.htm
It also looks like you could get rid of some of your dims if you used more = constraints
(if you can get them to work that is )
It really doesn't look that messy to me. Here is a couple of shots of one of mine ( Of
course I don't really work on it with all these sketches turned on)
Kent
Assistant Moderator
news:E0AA12166432C1A0EB23141C1F8CAE52@in.WebX.maYIadrTaRb...
*Dotson, Sean
Message 10 of 19 (82 Views)
Re:
10-29-2003 03:51 AM in reply to: *Martin, Lester
oohh. 350k worth of attachments.. I'm telling the mod... er nevermind...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:937B2DAED559675F0943F62ABE090713@in.WebX.maYIadrTaRb...
> Lester
see is .... why
= constraints
one of mine ( Of
> Kent
> Assistant Moderator
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
