Inventor General
ajohnson1993
Message 1 of 8 (518 Views)
Need help with materials when importing to Showcase
518 Views, 7 Replies
01-02-2013 01:13 PM
Hey guys, I have run into a couple of problems while trying to finish up my design. I used inventor to move and allign materials (I am using the Carbon Fiber texture from the Autodesk Material Library) and I got it looking how I wanted it to and then I imported it into Showcase and the texture does not show but instead is replaced with a gray default texture. I then tried using the material library in Showcase to apply the textures but I cant move and allign them as easily as I did in Inventor.
I noticed when you use the Showcase materials they have an Autofit option which seemed to work well, but you seem to not be able to do this with Autodesk materials. Since I don't like the Showcase carbon fiber texture is there a way I can take the carbon fiber texture from the Autodesk Library and use it in place of the Showcase version so I am able to autofit it? Another solution to my problem would be if I am able to import the textures exactly how I had them in Inventor, I tried this but it only imports with a default gray texture.
Any help would be appreciated, thank you ahead of time!
blair
Message 2 of 8 (515 Views)
Re: Need help with materials when importing to Showcase
01-02-2013 01:21 PM in reply to: ajohnson1993
If you used the IV2013 Autodesk Material Library, it should be consistant with the Showcase Autodesk Library. Make sure you are current on the Showcase SP's, Showcase 2013 is on SP3.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
ajohnson1993
Message 3 of 8 (500 Views)
01-02-2013 02:26 PM in reply to: blair
Ok so I updated to SP3 which made the texture show up on import! Now my only problem is that it didnt save the modifications I made to the texture in Inventor, such as rotation and scaling. Is there a way to import the model as is from inventor?
blair
Message 4 of 8 (492 Views)
01-02-2013 02:50 PM in reply to: ajohnson1993
Did you create a new texture in Inventor with the changes or did you just modify and save an existing one? There was some updates to the Materials and Appearance with the SP's for IV2013 as well.
Not really sure what else to suggest of than try posting to the Showcase forum.
Win7-64
ajohnson1993
Message 5 of 8 (487 Views)
01-02-2013 03:15 PM in reply to: blair
Well in Inventor the materials for each part I modified show up as CarbonFiber(2) and CarbonFiber(3) and so forth. Is this okay or is there another way I should be handling materials?
blair
Message 6 of 8 (482 Views)
01-02-2013 03:29 PM in reply to: ajohnson1993
Showcase may be looking at the Appearace and not the Materials. This was changed in Inventor 2013. Materials contains the physical properties such as mass and density, whereas the Appearance is only the finish.
I bet you that Showcase looks at only the Appearance.
Think of Materials and Appearance in Inventor this way.
Materials: Steel, with a default apperance of Grey. You can still have the Materials: Steel with an appearance of Blue or Green.
Showcase dosn't care about the physical properties such as Mass or Density, only the appearance.
Win7-64
ajohnson1993
Message 7 of 8 (479 Views)
01-02-2013 04:04 PM in reply to: blair
Okay sorry I have been reffering to the wrong thing then because I am using the appearance modifier, not the materials one. So even in that case Showcase should be using those materials with the same settings correct? Because as of right now I allign everything in Inventor then when I import it to Showcase everything is rotated back to its original position.
blair
Message 8 of 8 (472 Views)
01-02-2013 07:25 PM in reply to: ajohnson1993
If you have modified the Appearance item in Inventor, when you import the model into Showcase, it's looking for the closest match in Showcase.
You might want to post this in the Showcase forum. You might get better help.
Win7-64
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
