Inventor General
Valued Mentor
jeanchile
Message 1 of 4 (290 Views)
Need help filling a weld in a weldment.
290 Views, 3 Replies
09-01-2013 09:12 AM
Hello everyone,
I am currently working on a weldment for a bearing and have a question about the weld in the picture attached. How do I get the bevel weld on one side of the radial lip to fill the way I need it? If I select "Radial Fill", I can't select a fill direction. If I select a fill direction, I can't get the weld to fill radially (unless I create three different welds).
Any tips/suggestions?
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
JDMather
Message 2 of 4 (279 Views)
Re: Need help filling a weld in a weldment.
09-01-2013 09:29 AM in reply to: jeanchile
Can you attach the assembly here?  (I guess I could make up a quick dummy assembly - but I am feeling lazy today.)
Can you use the Split (Face) command to isolate the face you want welded?
Well, now it looks like I wasn't so lazy after all and not alone on that count.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
yannick3
Message 3 of 4 (270 Views)
Re : Need help filling a weld in a weldment.
09-01-2013 09:40 AM in reply to: jeanchile
Hi
The only way is to split face,create construction plane and use split feature.
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Valued Mentor
jeanchile
Message 4 of 4 (246 Views)
09-01-2013 11:23 AM in reply to: JDMather
Umm... Yes. Yes I certainly can. :smileyembarrassed: This is only the third model I have done where I needed to show the actual welds and I'm a little embarrassed I didn't think of that.
Thank you JD (and Yannick) for the (now obvious) suggestion. Please enjoy the rest of your weekend and tell your bosses I said you get a raise.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
