Keith, You already have a part (called TranD01-Block) that could serve as
the
base for four derived parts, like Kent describes below. You should be able
to
completely dispense with the Excel spreadsheet.
The "included angle" between the arbtrarily oriented planar faces can be
found
by setting up a plane that is normal to the two planes. Then you can project
the
two planes to a sketch you set up on the plane you created, and define an
angular dimension between the two lines. (It seems that you need these
angles
for sheet metal bends).
You could create all these driven angular dimensions in the base part
mentioned
above and export them to the 4 derived parts.
"Kent Keller" wrote in message
news:79D5DB552FE03F31E0C4AB1020063AAF@in.WebX.maYIadrTaRb...
> Keith
> It complained about some things missing when I opened it, but it all
appears there. I
> agree that method does look like a lot of work. I don't even know where
to start editing
> it without causing it to blow up.
> For something like this instead of using the wireframe method like I
posted, start a part
> file and make a part the shape of the inside of the duct. Then derive
this into the new
> sheetmetal files as a surface and build the sheets on the surface, and
reference the
> surface edges for the SM edges. If you change the core model then the SM
parts will also
> change. There have been a couple examples of this posted to customer
files in the past.
> Not sure if they are still there or not.
> Kent
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> When posting Attachments Please Zip first and Use the new IVCF
> Web http://discussion.autodesk.com/WebX?14@186.Fx3taaT3ofu.79@.f15ad3a
> Newsreader
news://discussion.autodesk.com/autodesk.inventor.customer-files
> "kbodoh" wrote in message
news:f160fd4.6@WebX.maYIadrTaRb...
> > Check out my TranD01 file in IVCF. This works but Excel drives through
parameters.
> Setting up a model like this takes alot of work. Then I have to Pack&Go,
change file
> names, resolve links, update driven dimensions, and clean up the drawings.
Do you have
> experience working with non-perpendicular sheet metal parts like this? I
am afraid that
> skeletal modeling will require many work planes and sketches -- all
capable of failing
> during update.
> > Thanks, Keith
