Inventor General
Valued Mentor
meck
Message 1 of 11 (287 Views)
Multiple base view properties
287 Views, 10 Replies
12-03-2012 08:19 AM
I have a drawing that has multiple base views on it. These are parts of an assembly that need detailed. I do not wish to create 50+ separate drawings for all of these details. Each part needs the iproperties from their model placed on the sheet next to the part.
I can place the first part's iproperties using the Format Text dialog box and getting the iproperties from the part model without any problem. When I try to do the same with the second base view I've placed on the drawing it still gives me the first part's iproperties.
Is it possible to do what I want without manually writing the iproperty text for each part? It there a better way than what I am doing?
Thanks in advance!
Mike Eck
Senior Designer/ CAD Programmer
Howden North America
Using Inventor 2013
cbenner
Message 2 of 11 (273 Views)
Re: Multiple base view properties
12-03-2012 09:44 AM in reply to: meck
From what I can tell, notes placed on the drawing will take all the iproperties from the first model placed as a view.  However, notes attached with a leader will take iproperties from the model in that view.  I'm not sure if there is any other way to force this to work.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Mentor
meck
Message 3 of 11 (268 Views)
12-03-2012 09:52 AM in reply to: meck
Good enough. I'll just delete the leader afterwards!
Thanks!
Mike Eck
Using Inventor 2013
cbenner
Message 4 of 11 (264 Views)
12-03-2012 10:02 AM in reply to: meck
Depending on how you designed your titleblocks, you may have a problem there as well.  If it was set up to use Model Properties, it will grab those from the first model placed.  We use a special titleblock for what you are describing, that pulls it's values form Drawing Properties.
ChrisB
Valued Contributor
EScales
Message 5 of 11 (260 Views)
12-03-2012 10:17 AM in reply to: meck
Try this...edit your View Identifier in your Styles Editor.  Not only can you have it display the View Name and View Scale, but you can also add any Model Properties.  Let's say you wanted the material listed with each base view...edit the View Identifier in the Styles Editor and add the "Material" property to your text.  Each time you place a base view and turn on the View Identifier, the material will display for the part in that view.  After the view is placed, you can move the View Identifier to a different location around the view, if you don't want it directly underneath.
Eric
Please select "Accept as Solution" if this answers your question.
Valued Mentor
meck
Message 6 of 11 (255 Views)
12-03-2012 10:29 AM in reply to: EScales
This is way better than what I was trying to do.
Thanks!
Mike Eck
Using Inventor 2013
Valued Mentor
meck
Message 7 of 11 (219 Views)
12-04-2012 07:12 AM in reply to: EScales
Your suggestion has been working great. Just to raise the bar a bit... Is there a way to get the item number from the assembly to show up in the view identifier or a note also?
Mike Eck
Using Inventor 2013
Valued Contributor
EScales
Message 8 of 11 (210 Views)
12-04-2012 07:21 AM in reply to: meck
That's a tough one because a parts list is connected to a specific assembly view.  When creating a parts list, you have to select the view you want to create item numbers for.  I've encountered this question before and I don't think we came up with a solution, but let me revisit this and think about it.
Eric
Valued Mentor
meck
Message 9 of 11 (206 Views)
12-04-2012 07:49 AM in reply to: EScales
I'd appreciate any help.
Mike Eck
Using Inventor 2013
Valued Contributor
EScales
Message 10 of 11 (192 Views)
12-04-2012 12:18 PM in reply to: meck
Well, there doesn't seem to be any way to do this...at least not that I can come up with.  I have submitted this topic to the Inventor IdeaStation (Wishlist), so maybe we'll get lucky and the developers will consider adding such functionality.
Here's the idea that I added: http://forums.autodesk.com/t5/Inventor-IdeaStation/Item-Number-from-Parts-List-as-an-Available-Prope...  Give it some kudos, maybe it will help.  :smileyhappy:
Eric
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
