Inventor Forum
Moving from 2012 to 2014, VBA Compile Error.
6 REPLIES 6
shastu
1647 Views, 6 Replies
I just upgraded Inventor from 2012 to 2014.  Now when I try to run any of my macros, I get a "Microsoft Visual Basic for Applicaitons" dialog box that reads:  "Compile Error:  The code in this project must be updated for use on 64-bit systems.  Please review and update Declare statements and then mark them with the PtrSafe attribute."  This must be a bogus error because I did not go from a 32 bit system to a 64 bit system.  I was on a 64 bit system with 2012.  All I did was upgrade Inventor from 2012 to 2014.
6 REPLIES 6
MegaJerk
in reply to: shastu
While I am not certain about what is causing your problem (perhaps you could post some simple problematic code for us) I do know that Inventor 2012, while it may be installed 64bit, has integration to the VBA environment that is 32bit only. It is for this reason why when you start up VBA (or call anything VBA related) an intermediary process ‘InventorHost32bit’ is launched and runs along side everything.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
mrattray
in reply to: MegaJerk
VBA in 2014 was upgraded to run natively in 64 bit (VBA 6 to 7?). As a result all your macros must be updated to use native 64 bit calls. Architecture sensitive functions aren't common, but I did hit this problem myself. The fix was pretty simple. Post your code here and we'll see if we can give it a tweak.
By the way, there's lots of programming information on the Inventor Customization board. It's usually better to post and search there for programming stuff.
Mike (not Matt) Rattray
shastu
in reply to: mrattray
Below is what it seems to have a problem with:
Public Declare Function GetSaveFileName Lib _ "comdlg32.dll" Alias "GetSaveFileNameA" _ (pOpenfilename As OPENFILENAME) As Long
Public Declare Function GetOpenFileName Lib _ "comdlg32.dll" Alias "GetOpenFileNameA" _ (pOpenfilename As OPENFILENAME) As Long
shastu
in reply to: shastu
I went ahead and just put PtrSafe inbetween Declare and Function in both spots and it seems to work now.  Didn't think it would be that easy.  Is there anything else I should have done?
Curtis_Waguespack
in reply to: shastu
Hi shastu,
You might search on the Inventor Customization forum, where VBA questions are more likely to have been asked & answered in the past:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
 Here are a couple of links that seems related (I just took a quick glance):
http://forums.autodesk.com/t5/Inventor-Customization/Inventor-2014-64-bit-breaks-database-connection...
http://forums.autodesk.com/t5/Inventor-Customization/MacroControlDefinition-does-not-work-in-2014/m-...
I hope this helps.
Curtis
mrattray
in reply to: shastu
If it works, it works.
