I do not know if this is possible to do, but can you take faces off a solid body. For example, If you created a cube that is shelled , can you explode the cube and separate the faces off the cube so that you have individual rectangle faces to move them around?
Why?
i don't know why you want to do this. But i think you can use Offset command to offset some individual faces from the cube.
