I have an assembly that has a part I would like to be able to move using a driven constraint. The part is a pin that I would like to follow an odd shaped slot.
How would I go about doing that?
Any suggestions?
Rich
Solved by JDMather. Go to Solution.
Transistional Constraint.
Angle or Offset Mate constraint to drive.
or
Use appropriate Dynamic Simulation joints if you have Inventor Professional.
Attach your assembly here.
The CADWhisperer YouTube Channel
Huh?
