Inventor Forum
Move detail view to a different sheet in Inventor 2009
5 REPLIES 5
smithme1967
6091 Views, 5 Replies
How can I move a detail view to another sheet in a drawing in 2009? I have only been able to copy the detail and it's parent view to the 2nd sheet and then suppress the parent view on the 2nd sheet so that only the detail view is visible. However, when I go back to the first sheet and try to suppress or delete the detail view, it also deletes/suppresses the detail circle from the parent view.
5 REPLIES 5
mcgyvr
in reply to: smithme1967
I forgot how it works in 2009 (might/should be the same) but with 2011 you simply drag the detail view (from the model browser) down to the sheet you want it on. You have to make sure that the sheet that the detail is on (when you start) is the active sheet.
smithme1967
That worked, thank you!
Ktelang
Thats to both of you this thread helped  Man Very Happy
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
c.vasquez
Cant get this trick to work in Inventor 2013! It wont allow me to drop thedetail view on the new sheet. Please advice
Carlos
c.vasquez
in reply to: c.vasquez
Never mind! I was creating the second sheet incorrectly.
