Inventor General
Active Member
Message 1 of 6 (2,675 Views)
Move detail view to a different sheet in Inventor 2009
2675 Views, 5 Replies
05-14-2010 01:12 PM
How can I move a detail view to another sheet in a drawing in 2009? I have only been able to copy the detail and it's parent view to the 2nd sheet and then suppress the parent view on the 2nd sheet so that only the detail view is visible. However, when I go back to the first sheet and try to suppress or delete the detail view, it also deletes/suppresses the detail circle from the parent view.
*Expert Elite*
mcgyvr
Message 2 of 6 (2,675 Views)
Re: Move detail view to a different sheet in Inventor 2009
05-14-2010 01:23 PM in reply to: smithme1967
I forgot how it works in 2009 (might/should be the same) but with 2011 you simply drag the detail view (from the model browser) down to the sheet you want it on. You have to make sure that the sheet that the detail is on (when you start) is the active sheet.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Member
Message 3 of 6 (2,675 Views)
05-14-2010 01:30 PM in reply to: smithme1967
That worked, thank you!
Valued Mentor
Ktelang
Message 4 of 6 (2,647 Views)
09-23-2010 07:49 AM in reply to: smithme1967
Thats to both of you this thread helped  :manvery-happy:
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Member
Message 5 of 6 (1,943 Views)
06-27-2012 08:26 AM in reply to: smithme1967
Cant get this trick to work in Inventor 2013! It wont allow me to drop thedetail view on the new sheet. Please advice
Carlos
Member
Message 6 of 6 (1,938 Views)
06-27-2012 08:39 AM in reply to: c.vasquez
Never mind! I was creating the second sheet incorrectly.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
