Sorry, I did go look at the part and unfortunately I don't have any good answers. I
imagine it could be done with a vba routine, but it would probably take as long to write
that as it would to do what you want manually.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Jürgen Wagner" wrote in message
news:477242F77ECAD25CB2D68F61E19F6B64@in.WebX.maYIadrTaRb...
> Hi Kent,
> if I do a circualar Array the Part(s) Sprosse don't have the right position
> because the Arrayfunction don't consider of the constraints. if you want,
> look at the Files then you see what i mean.
> Juergen
