I am working on a set of gears. When I go to try to make them rotate together, they always go the wrong way, regardless of if I select forward and reverse. It also takes applying this constraint multiple times to make it work, and then It only works if you try to turn a certain gear. It will not turn at all if you try to use the other gear. I have attached the .iam so you can get a better idea of what is happening. If you can give me a good explanation on how to fix this I would be very grateful.
Only IAM file?
You have so send also all the ipts.
Make a Pack & Go to join all the project components in one folder.
File > Save Copy As > Pack and Go
Not sure how to do this.. maybe the log will do this, but there are a lot of parts here, more than it will let me upload.
forget the pack and go since you don't know how to use it.
Just attach all the ipt files here that go with your iam file.
