Bob S. wrote:
> Good luck getting it to work on IMPORTED data though.
> Most of the files I get imported into IV fail on these
> more complex commands, though I have some workarounds
> for adding some features when they fail. Not sure you
> are using imported data or not, just thought I'd point
> out that issue.
You're certainly right about the IMPORTED data problem. Fillets are
major problem, they can stop a simple part split before your finger is
off the button. Seems that many designers have heard that sharp corners
will cause stresses in molded parts; so they hit the "fillet all"
button. Without the fillets, most of the IV operations would have been
fine.
Billy Hiebert
HIEBERT SCULPTURE WORKS
Small Part Injection Molding
http://www.hieberts.com
> tahdesign wrote:
>>Thanks to all of you,
>>I just did a simple example for the molding eng to show the steps involved in the adaptive subtraction.
>>Just wanted to show some method that IV could do this.
