Inventor General
New Member
huwu
Message 1 of 7 (404 Views)
Mold design library does not work properly
404 Views, 6 Replies
08-17-2011 02:26 AM
I downloaded the full package of mold design library and installed it following instruction. Unfortunately, it does not work properly. I failed to insert a mold base after creating core and cavity. The pop up window of Vendor and Type is empty. Please help me to sort out this problem. Thank you very much.
HW
Message 2 of 7 (398 Views)
Re: Mold design library does not work properly
08-17-2011 04:42 AM in reply to: huwu
Is this what you see in your Projects settings?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
huwu
Message 3 of 7 (373 Views)
08-17-2011 05:43 PM in reply to: JDMather
Thank you very much JDMather. Problem solved.
Distinguished Contributor
Message 4 of 7 (299 Views)
04-26-2012 10:49 PM in reply to: huwu
Here's a quick tip using the dialog box that J.D. Uploaded.  After installing all 3 libraries, use the same dialog box to filter out libraries you won't need for a particular mold.  Based on what's available within the 3 libraries, I see that the only Imperial Mold Base comes from DME Manufacturing.  The majority of the Mold Bases are located in either the Metric Library or the Meusburger Library.  Both of these libraries are metric only.  If you find yourself doing this often, I would highly suggest that you set-up new projects to reflect the mold library you wish to use for a particular mold modeling job.
I also noticed that the Inventor 2013 WikiHelp has an error directing you to load the 2012 version of the 3 same libraries to include mold bases not included during installation.  2012.idcl and 2013.idcl files don't mix!  Check the 2013 Updates and Service Packs for the correct versions of the mold.idcl files for 2013.
Hope that helps!
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013 & 2014
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
Product Support
Message 5 of 7 (284 Views)
04-27-2012 04:55 PM in reply to: JimStrenk
Jim,
On this wiki help page we advise to go to this 2013 download location to install the additional mold alibraries.
So I don't see the version mismatch unless you are referring to a different help section of course.
Bob
Message 6 of 7 (280 Views)
04-27-2012 11:46 PM in reply to: bobvdd
bobvdd wrote:
Jim,
On this wiki help page we advise to go to this 2013 download location to install the additional mold libraries.
Bob
Bob, your absolutely correct.  No mismatching within the Inventor Tooling Tutorial.  I did see the error however within the the WikiHelp section of Tooling, towards the bottom of the Indiscies area on the left side of the page.  I think it's within the first three paragraphs.
I've also noticed that when beginning a Mold Design session, the check box meant to send you to the tooling tutorial sends to the top of the top of the Inventor 2013 WikiHelp pages rather than the expect tutorials section.
Jim Strenk
Product Support
Message 7 of 7 (258 Views)
04-30-2012 11:38 AM in reply to: JimStrenk
Jim,
I could not locate the topic in the "bottom of the index". Screenshot perhaps?
But I did log a defect for the fact that you are redirercted to the wrong place in the wiki when checking the tutorial checkbox : 1460659 Mold tutorial cannot be reached when creating a new Mold assembly
Good catch. Thanks for reportting this.
Bob
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
