OK, I have a steel tube at 18in.. I want to 45 one end. I cannot find the process. Need Direction. Pleeeease?
Solved by cwhetten. Go to Solution.
Solved by cbenner. Go to Solution.
More info... Do you want to modify it IN the content center, or have you placed it in an assembly and you want to modify it there?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Double click the part in your assembly to activate it. Add a 45 degree cut extrusion on the end you need it on.
Chris Benner
Find the midplane running through your tube, and create a new sketch on that plane, like this:
Finish the sketch and select the Extrude tool, select the profile and set it to remove material, symetrically, through all... as here:
Hit ok, and this is what you should have:
Have you had much Inventor training on basic modeling techniques? If not, hit the Get Started toolbar, and run though some of the basic tutorials.
Or am I still not seeing what you want to do?
Chris Benner
