Hi All,
I have an iassembly with iparts involved. I was wondering if it is possible to change a constraint based on a user parameter.
For example I would like to create a work plane which is used to mate another plane flush. The parameter I would change is the angle of this plane. In some cases it would be 45 degrees from the YZ plane, in other cases it might be flush also. I would like to either add a user parameter that would be used as a place holder in the constraints box to allow for it to be modifiable, or I would like to add the constraint itself to the iassembly table and modify it there based on the different assemblies chosen.
Is this possible?
Vijai Christopher Sookrah
Mechanical Engineer, EIT
Aircraft Appliances & Equipment Ltd.
