Well here's a start. I took snaps as I created the stuff. I don't have time
to make a "tutorial" per se, so if you have questions about the snaps as you
look at the Inventor parts and assembly, just post 'em here.
Also I have a habit of putting the master sketch into the assembly, for ease
of access. Usually I'll turn the visibility of it off tho. You don't have to
put the master sketch into the assembly - it just drives the parts.
As for the 4 levels I'm sure you can work out a viable solution for that.
I use KwikInsertNFix to bring the panels into the assembly after I've
created them.
So basically I loft the "internal volume" of the hopper and then "skin out"
the hopper, using this "internal volume" as my root file. Notice when I
derive the root part I use the root part as a surface, not a solid.
One last thing, I made the HopperHt variable, and so if you want something
beside 100, just open the master sketch, or root, part and click on the
little f of x symbol to edit the height of it. Hope this is enough to get
you on your way.
wrote in message news:4987589@discussion.autodesk.com...
Here's is what I meant. This is made up of 4 solids (sides) which where then
sliced 4 times top to bottom (these levels are what the customer is asking
for).
