Inventor Forum
Model Crashes during edit
5 REPLIES 5
bhowe
102 Views, 5 Replies
I have one model on my system, that will crash as soon as I try to edit any attribute. By crashing, I mean it shuts Inventor off. I am using IV6 with SP1. I have tried this on a couple of different computers with the same result. I would like to upload the model for your analysis. I can't remember where the upload area is.Please give me a path, or directions. Has anyone else experienced this? I need to modify this model!
A Little help please, AutoDesk!
Bill
Thank You
Bill
Inventor 2011 Pro 64 bit
Windows XP Pro 64 bit
Dell Precision PWS390
Intel Core 2 CPU 6700 @2.66GHz
7.93 GHz Ram
ATI FireGL V7200
5 REPLIES 5
in reply to: bhowe
I believe this link will get you there.
Keith
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
AutoDesk!
Bill
in reply to: bhowe
I filed a defect against the crash. I rolled the end of part marker to the
top, and then rolled it back down one feature at a time to find the problem.
Sketch11 has bad reference geometry. This is probably what causes
Revolution2 to crash. I posted the rolled back part to CF. You will have to
use that to rebuild the last couple of features or go back to an old version
that is stable.
Loren Jahraus
Autodesk Inventor Workflow Team
"bhowe" wrote in message
news:f12778b.-1@WebX.maYIadrTaRb...
> Thanks,
> Bill
in reply to: bhowe
Loren, sorry to go off on a tangent, but was wondering; Is the ability to
delete features below the EOP in the works for future releases?
Jeff
"Loren Jahraus (Autodesk)" wrote in message
news:BBE94B018C1E42D0B23275902C45FB89@in.WebX.maYIadrTaRb...
I rolled the end of part marker to the top, and then rolled it back down one
in reply to: bhowe
Jeff
Paste this in a VBA module .... won't work with SM parts, but should be OK with regular
parts.
Option Explicit
Public Sub KillFeaturesPastEOP()
Dim oPDoc As PartDocument
Set oPDoc = ThisApplication.ActiveDocument
Dim oFeatures As PartFeatures
Set oFeatures = oPDoc.ComponentDefinition.Features
Dim oFeature As PartFeature
For Each oFeature In oFeatures
If oFeature.HealthStatus = kBeyondStopNodeHealth Then
oFeature.Delete
End If
Next
End Sub
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Jeff Howard" wrote in message
news:B7EE2D693E18ACA4DECEF8BEA387ACD2@in.WebX.maYIadrTaRb...
> Jeff
in reply to: bhowe
Many thanks, Kent.
"Kent Keller" wrote in message
news:F4F17F3A86137B99A2B770F5FDCC65A8@in.WebX.maYIadrTaRb...
.. ability to delete features below the EOP ......
