Inventor General
Active Member
Message 1 of 7 (151 Views)
Accepted Solution
Model Animation
151 Views, 6 Replies
11-25-2013 09:14 AM
I have created a 3D model of a gimble, with a supporting frame, an outer frame rotating about one axis, and another frame rotating withing that on another axis. When I have the assembly in the 'assemble' view, I have defined my constraints and can rotate the outer and inner frames independantly. When I switch to the 'studio' environment and try to animate the assembly, the inner frame can be animated, however the outer frame won't move.
Daniel Hutton
*Expert Elite*
Message 2 of 7 (145 Views)
Re: Model Animation
11-25-2013 09:42 AM in reply to: djh692
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 3 of 7 (141 Views)
Re: Model Animation
11-25-2013 09:49 AM in reply to: JDMather
Ah, I thought that might be the case, i will have to post twice to include all parts
thanks,
daniel
Daniel Hutton
Active Member
Message 4 of 7 (139 Views)
Re: Model Animation
Active Member
Message 5 of 7 (136 Views)
Re: Model Animation
11-25-2013 09:50 AM in reply to: JDMather
*Expert Elite*
Message 6 of 7 (107 Views)
Re: Model Animation
11-25-2013 11:22 AM in reply to: djh692
I would add angle constraints to control the motion (you won't be able to free drag - but will be able to operate more realistically.
Then I would Animate Constraints the angle constraints.
Better yet -
don't use the angle constraints (although your motor shafts should be connected to frames) and start learning the Environments>Dynamic Simulation.
Active Member
Message 7 of 7 (104 Views)
Re: Model Animation
11-25-2013 11:23 AM in reply to: JDMather
Much appreciated!
Daniel Hutton
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
